WLED: fixing entity name
Hey guys,
I’ve just started using WLED with HA and have some problem for basic turn on/off WLED using the dashboard.
I’ve a WLED called wled_rainbow with 2 saved presets.
  • 1 = no segment define
  • 2 = 5 segments
Starting WLED with preset 1, I can see the following entity in HA:
  • light.wled_rainbow
  • switch.wled_rainbow_nightlight
Looks good, so I create a sample switch on/off on lovelace for “light.wled_rainbow” and everything is working fine.
Now, I switch to preset 2 and I have these entities:
  • light.wled_rainbow_master
  • light.wled_rainbow_segment_1
  • light.wled_rainbow_segment_2
  • light.wled_rainbow_segment_3
  • light.wled_rainbow_segment_4
  • light.wled_rainbow_segment_5
If I use lovelace to switch on/off “light.wled_rainbow”, it affect ONLY the first segment of the strip led.
So, I can’t use “light.wled_rainbow_master” on preset 1, because it doesn’t exist and “light.wled_rainbow” doesn’t seem to do the job.
How do you guys handle this ? Is it possible to see and control entity “light.wled_rainbow_master” even if no segment are define ?
Thank you guys in advance for any help you can provide me with!
EDIT: can be usefull
  • WLED v0.11.1 “Mirai” build 2101130
  • HA 2021.1.4
Hey
i added one extra LED in the wled config.
If you got 120, your config is 121.
in every preset i have a segment with led 121.
so i got the light.wled_master every time.
also i set under WLED setting LED Preferences
Apply preset 1 (or any preset you choose)
for getting the master again after reboot.
Regards
Jens
