Currently WLED integration reads and publishes WLED segments as separate Entities,
If you want to program a Scene and add an entity it also does load the device.
When the device is loaded you need to set the status for ALL entities to complete a scene.
This makes it very hard to create automations based on external conditions.
Purpose:
Indicator lamp with 3 segments
Bottom Segment > Low wattage (Green) Medium wattage (Yellow) High wattage (Red)
Mid segment > Inside temp Cold (Blue) / inside temp normal (Green) / Inside temp Hot (Red) > Heating Active (sparkle effect)
Top: Outside temp Cold (Blue) / Outside temp normal (Green) / Outside temp Hot (Red) > Rain (sparkle effect)
