WLED Integration devices becoming unknown
Has anyone else had any issues with WLED devices consistently becoming unknown/unavailable though the day? I have 4 different devices (2 Glepopto Controllers and two ESP32 flashed boards) that all exhibit the same behavior. They are all flashed with the newest firmware and I’ve deleted the integration and restarted it multiple times with no success. Below is a snapshot of my activity log for a couple hours on one of the devices. Any thoughts? It’s driving me mad!!
Activity
April 9, 2026
WLED - Test Firmware turned off
7:43:36 AM - 2 hours ago
WLED - Test Reverse turned off
WLED - Test Sync receive turned on
WLED - Test Sync send turned off
WLED - Test Nightlight turned off
WLED - Test IP changed to 192.168.1.199
WLED - Test Color palette changed to * Colors 1&2
WLED - Test Preset became unknown
WLED - Test Live override changed to Off
WLED - Test Intensity changed to 128
WLED - Test Speed changed to 128
WLED - Test turned off
WLED - Test Restart became unknown
WLED - Test Firmware became unavailable
7:43:30 AM - 2 hours ago
WLED - Test Reverse became unavailable
WLED - Test Sync receive became unavailable
WLED - Test Sync send became unavailable
WLED - Test Nightlight became unavailable
WLED - Test IP became unavailable
WLED - Test Color palette became unavailable
WLED - Test Preset became unavailable
WLED - Test Live override became unavailable
WLED - Test Intensity became unavailable
WLED - Test Speed became unavailable
WLED - Test became unavailable
WLED - Test Restart became unavailable
7:22:18 AM - 2 hours ago
This goes on throughout the day…usually once, sometimes twice an hour across all WLED devices.
Sounds like a WIFI problem maybe.
You could set the ESP’s to be able to watch the log and see what it is doing.
I thought it might be a wifi issue at first as well, but it seems odd that it only becomes unavailable for a split second and them re-establishes itself. I would think if it was a WIFI problem the timeout period would be longer. Than a second or two.
Are these espHome?
I have one ESP32 board flashed directly with WLED and another D1 Mini 8266 board flash with WLED as well.
