WLED Integration - Not showing all sensors (Entities) from WLED device
Hi All…
Sorry if this has been posted before. Searching, I only found one similar issue back in Dec 2024, but that was to do with current reporting when device was on and Leds were off.
I’ve upgraded one of my WLED devices to 0.15.1 and noticed that not all sensors (entities) are available in Home Assistant.
The main entity is the Estimated Current that I need.
I have deleted the device and entities in HA, rebooted HA to clear up the device, then re-added, but still it shows only 21 out of 24 possible entities that are brought in from adding the device.
If I go to the device and request info from the API (/json/info) it does return the data, so pointing more to WLED HA Integration.
From the JSON, I get this info:
  "leds": {
    "count": 611,
    "pwr": 1360,
    "fps": 43,
    "maxpwr": 0,
    "maxseg": 32,
    "bootps": 3,
    "seglc": [1],
    "lc": 1,
    "rgbw": false,
    "wv": 0,
    "cct": 0
The only enitity that is brought into HA from that LEDS block is the LED Count, and not the LED pwr.
I have check other WLED devices on 0.14.4 and the Entities are brought into HA, including the Estimated Current (“pwr” in the Json). Checking the JSON between the versions, it is identical (so keynames have not changed).
I presume Im on the latest WLED HA Integration version (cant find where to find the version for it).
My HA system Versions are:
  • Core - 2025.10.4
  • Supervisor - 2025.10.0
  • Operating System - 16.2
  • Frontend - 20251001.4
Also, can you add other entities such as Temperature? My WLED device reports Temperature and it is in the Json as well, labelled as a senor
  "sensor": {
    "temperature": [27, "°C"
Thanks,
Rob
Hello Rob Brown,
¯\(ツ)/¯ Sounds like you are looking for…
Feature requests are not handled here.
Hi @Sir_Goodenough
What is a feature request? The Temperature part, ok, but the main issue is the problem where WLED 0.15.0 and 0.15.1 and the integration into Home Assistant does not bring in all the Entities it used to. This is not a feature request when it used to work.
Specifically, the Current entity which under WLED 0.14 (any minor version and previous WLED versions) always bought in the Current reading and a few other entities which now have disappeared.
My other WLED 0.14 devices, connected to HA, shows current and these other missing entities (which dont really care about those others).
Thanks, Rob
