WLED integration
Hi guys!
I’m just not able to make the WLED integration run. Adding the integration went normal, the device is online and it looks like it has no issue. But all the related entities are unavailable. Tried to delete the integration and delete the entities. Without any success. The entities are unavailable and related to WLED integration therefore unable to delete. How can I get rid of them? Reinstalled the integration - entities still unavailable. Do you guys have an idea how to solve this issue?
well it’s surely one of the integrtations which if ever might reach the rusted metal badge against getting platinum level :slight_smile:
Gave me way to many issues, so I stepped back, and added a webpage pointing to the IP of the master WLED device and placed that in a panel (single card) view in HA.
Using the WLed GUI for setup is more straight forward, especially if you have multiple controllers virtually linked to each other.
And you could easily switch LEDs on/off using either the HTTP or JSON API.
But it depends what you’re after, if you want to drive the LEDs through automations or scripts you likely need the integration.
