Hello all,
I hope this is the correct spot for this issue. I’m new to Home Assistant and most things attached to that subject (basic Raspberry Pi/Arduino projects in the past). I recently received the following:
NodeMcu: V3 with ESP8266
LED: ALITOVE WS2812B
Power Supply: 5v 20amp
*I can send links for the exact product if that helps
I’ll start with the obvious/key issues I’ve noticed. The wifi doesn’t work if I boot the NodeMcu while the D4 pin is connected. I’ve seen other issues similar online however they either have no solution or I tried and it didn’t work. I’ve used a multimeter on the other end of the LED strip and I’m getting around 4.9 volts so I don’t think its a current issue (could be wrong). Direct output from the PSU is 5.7volts.
Wiring: The LED and NodeMcu are connected to the PSU (NodeMcu Vin/Gnd). Not my original configuration, however, I tried to eliminate some jumpers.
I’ve tried 2 different versions of WLED but same results. I’m not using a resister, however, I’ve seen this work without the use of one. I’m hoping I’m overlooking something simple. The LED’s worked for my last project (running off a Raspberry Pi) so I wouldn’t imagine they are bad. I can test them if needed, I just would have to set all of that back up again. Any advice would be appreciated and I’m sorry if this is either a dumb or already answered question (I promise I did research first, lol)
Thanks!
