WLED Presets and Effects controlled by (zigbee2mqtt) IKEA Styrbar button
Figured someone might find this useful if you have your Styrbar linked via zigbee2mqtt.
Amend your config for the sensor name of your Styrbar unit and the first option for your preferred WLED preset.
Buttons work as follows:
Up: WLED on using preferred Preset
Down: WLED off (with 1 sec transition)
Short press right: cycle to next preset
Short press left: cycle to previous preset
Long press right: cycle to next effect
Long press left: cycle to previous effect
- id: '166396696034'
  alias: Styrbar Keuken
  description: Id 3
  use_blueprint:
    path: homeassistant/Z2M - IKEA STYRBAR 4-button remote.yaml
    input:
      remote: sensor.ikea_styrbar_keuken_action
      button_on:
      - service: select.select_option
          option: Warm Wit
          entity_id: select.wled_preset_2
      button_off:
      - service: light.turn_off
          transition: 1
          entity_id: light.wled_2
      button_brightness_move_up:
      - service: light.turn_on
          brightness_step_pct: 10
      button_brightness_move_down:
          brightness_step_pct: -10
      button_left_click:
        data_template:
          option: '{% set options = state_attr(''select.wled_preset_2'',''options'')
            %} {% set  current_selection = states(''select.wled_preset_2'')%} {% if
            (current_selection) == "unknown" %} {{ "Warm Wit" }} {% else %} {% set
            selection = options.index(current_selection) %} {% if (selection - 1)
            >= options | length %} {{ options[0] }} {% else %} {{ options[selection
            - 1] }} {% endif %} {% endif %}
      button_left_hold:
        data_template:
          effect: '{% set effects = state_attr(''light.wled_2'',''effect_list'') %}
            {% set current_selection = state_attr(''light.wled_2'',''effect'') %}
            {% set  selection = effects.index(current_selection) %} {% if (selection
            - 1) >= effects | length %} {{ effects[0] }} {% else %} {{ effects[selection
            - 1] }} {% endif %}
      button_right_click:
        data_template:
            selection = options.index(current_selection) %} {% if (selection + 1)
            + 1] }} {% endif %} {% endif %}
      button_right_hold:
        data_template:
            + 1) >= effects | length %} {{ effects[0] }} {% else %} {{ effects[selection
            + 1] }} {% endif %}
