c0ntax
(Martin)
April 11, 2024, 9:58am
1
I’ve just started out with WLED, with one Athom controller running a single LED strip. Literally just got it all connected and integrated to HA but I am struggling to get anywhere with a simple turn on in scripts.
At the moment I want a simple script to turn the light on (no effects) at a specific brightness and colour but it’s not working.
Can anyone please help out?
Current script:
kitchen_day:
alias: Kitchen Day
sequence:
- service: light.turn_on
entity_id: light.worktop_light_right
rgb_color:
- 240
- 215
- 170
- service: number.set_value
entity_id: number.worktop_light_right_intensity
value: 240
tom_l
April 11, 2024, 10:17am
2
That is not the brightness. It is the effect intensity. Try this:
kitchen_day:
alias: Kitchen Day
sequence:
effect: solid
brightness: 240
rgb_color:
- 240
- 215
- 170
c0ntax
(Martin)
April 11, 2024, 10:46am
3
Thanks Tom, but that isn’t working either.
I did try pretty much your whole script earlier but I hadn’t added the effect
but the script is
still not running when the automation is triggered. Nothing in logs.
tom_l
April 11, 2024, 11:19am
4
I just wrote this script for my wled lamp:
wled_test:
sequence:
entity_id: light.kerf_lamp
effect: solid
brightness: 240
rgb_color:
- 240
- 215
- 170
Called it from dev tools services and it worked perfectly.
So there is nothing wrong with your script (assuming th entity id is correct).
Did you reload scripts after writing it?
How are you calling the script?
What related errors are in your log?
c0ntax
(Martin)
April 11, 2024, 11:27am
5
Sorted now, @tom_l
I had reloaded the scripts in Dev Tools but, for some reason it needed a restart instead.
Thanks for your help.
tom_l
April 11, 2024, 11:28am
6
Is this the first time you have used scripts?
c0ntax
(Martin)
April 11, 2024, 11:32am
7
Not at all, no. But in the past, on a couple of occasions, I’ve found that an automation or script has required a restart instead of dev tools reload.
