WLED Unknown error occurred
I for some reason are unable to add a device, get the following error Unknown error occurred
I have wiped out the known_devices.yaml
Running the latest firmware on D1 mini, 5 of the six existing connected fine
Logger: aiohttp.server
Source: components/wled/config_flow.py:117
First occurred: 09:15:25 (2 occurrences)
Last logged: 09:15:28
Error handling request
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
    resp = await request_handler(request)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 222, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 82, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 136, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 180, in post
    return await super().post(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 73, in wrapper
    result = await method(view, request, data, *args, **kwargs)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
    result = await self._flow_mgr.async_configure(flow_id, data)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 280, in async_configure
    result = await self._async_handle_step(
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in _async_handle_step
    result: FlowResult = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/components/wled/config_flow.py", line 40, in async_step_user
    device = await self._async_get_device(user_input[CONF_HOST])
  File "/usr/src/homeassistant/homeassistant/components/wled/config_flow.py", line 117, in _async_get_device
    return await wled.update()
  File "/usr/local/lib/python3.10/site-packages/backoff/_async.py", line 133, in retry
    ret = await target(*args, **kwargs)
  File "/usr/local/lib/python3.10/site-packages/wled/wled.py", line 256, in update
    self._device = Device(data)
  File "/usr/local/lib/python3.10/site-packages/wled/models.py", line 658, in __init__
    self.update_from_dict(data)
  File "/usr/local/lib/python3.10/site-packages/wled/models.py", line 693, in update_from_dict
    presets = [
  File "/usr/local/lib/python3.10/site-packages/wled/models.py", line 694, in <listcomp>
    Preset.from_dict(int(preset_id), preset, self.effects, self.palettes)
ValueError: invalid literal for int() with base 10: 'rev'
Any ideas?
