I've managed to get my receiver to work however it is izarv2 and i've tried vairious ways to see if I can create one as its not included in the add on git hub.
Does any one have a working /config/wmbusmeters/etc/mqtt_discovery/izarv2.json that they can share with me please ?
First the important question: what are you using to receive the telegrams? A USB dongle plugged into your HA machine (RTL-SDR / IM871A / CUL…), or an ESP/gateway that publishes the raw frames to MQTT? That changes the answer a lot.
The etc/mqtt_discovery/<driver>.json per-driver files are part of the way your current add-on handles discovery — a separate template has to exist for every driver, and izarv2 simply is not bundled. That is the wall you have hit.
Full disclosure: I maintain a different wM-Bus add-on:
So take this with that grain of salt. It does not require any per-driver discovery JSON files. Home Assistant MQTT Discovery is generated dynamically from whatever fields wmbusmeters actually decodes. Therefore, once izarv2 is decoded correctly, its entities are created automatically — no izarv2.json is needed.
The catch, and the reason I am asking about your hardware, is that my add-on consumes raw HEX telegrams from an MQTT topic. You therefore need an ESP or another gateway publishing the received frames to MQTT. It does not currently read a USB dongle connected directly to the Home Assistant host.
So:
if you are already using an ESP → MQTT setup, it may solve this directly;
if your receiver is a USB dongle connected directly to Home Assistant, it will not be a drop-in replacement, and getting the discovery file working in your current add-on will probably be the easier option.
Tell me exactly which receiver you are using and I can say whether it is worth a look.
I use a RTL2832U on my Unraid server and ha vm (Blue usb on eBay ... RTL2832U + FC0012 entry-level RTL-SDR USB SDR Receiver 22-948MHz) which does seem to work except for the conversion to useable data.
I've looked up the meter and I believe it to be an Izar V2 type and actually unencrypted.
I can see a few around me too but always seem to fail at the last step in the conversion to usable.
I do seem to be getting something though...
"Started auto rtlwmbus[00000001] listening on t1
telegram=|1944304C424AC0209801A2_710300136380890A7B1089040A3326|+122
telegram=|1944304C424AC0209801A2_610300136397A643D0315ADDD12A24|+183
telegram=|1944304C424AC0209801A2_1103001363F26ABF81D461D0D06529|+210
telegram=|1944304C424AC0209801A2_3103001363DC342CD797C66366572C|+367
telegram=|1944304C424AC0209801A2_610300136397A643D0315ADDD12A24|+533"
I'll have a look at your addin too.
Let me know if I can add any more detail.
Looking at the izar.json file it would be good to understand the structure to see if I can work it in to a new one but not sure where to start really if your able to help ?
Good news: the radio side is working — your telegrams decode fine. I tested meter ID 20c04a42 with wmbusmeters: it decodes on both izar and izarv2, with the reading as total_m3. So the meter and the RTL‑SDR are fine — only the Home Assistant side is missing.
First confirm 20c04a42 is actually your meter, not a neighbour's — you mentioned you can see a few around you. Easiest check: decode it and compare the total_m3 against the reading on your physical meter. Use whichever id turns out to be yours below; I'll use 20c04a42 as the example.
You don't need anyone's izarv2.json. wmbusmeters just decodes and publishes the meter's JSON to MQTT; turning it into entities is the easy classic two‑step, no discovery template needed:
1) Tell wmbusmeters about the meter so it decodes and publishes it. A meter config like:
name=water
type=izar
id=20c04a42
key=
(unencrypted, so no key). It will then publish this meter's JSON to the topic wmbusmeters/20c04a42 (that's the per‑id convention — confirm the exact topic by subscribing with e.g. MQTT Explorer).
2) Point a Home Assistant sensor at that topic. In configuration.yaml:
(That's the modern form; the old sensor: - platform: mqtt style still works too. If you already have a top‑level mqtt: block, merge under it.) Reload via Developer Tools → YAML → Manually configured MQTT entities — no restart needed.
That's it — the sensor picks up the value as soon as the next telegram is published. Add more sensor blocks for the other fields you want (total_m3 is the same on both drivers; the extra field names differ between izar and izarv2, so use whatever your published JSON shows). The json_attributes_topic line also stuffs the full JSON onto the entity as attributes, handy for seeing every field at once.
