I’ve installed on both my win11 laptop and server2025 machine, and see the same on both.
They were both originally installed per-user, and I’ve updated them both a couple of versions of esphome since. I ran the updates as admin, which (inadvertently) moved things to program files.
That made me realise the options in the installer have moved since the screenshot on that page, so I reinstalled for all users from scratch.
To run it on the win11 laptop I’m using a shortcut to: “C:\Program Files\Python313\Scripts\esphome.exe” dashboard “C:\Users\user\Documents\ESPHome” --address localhost --open-ui
I’m using similar on the 2025 machine, but its being run as a service by nssm.
I get the same if I run it manually in either cmd or terminal.
Its the same in both Brave and Edge.
I’ve seen the same strange progress bars the whole time its been a separate install, but didn’t when I was using the HA add-on.
Python uses \n as the end-of-line character, which is fine for Unix-like systems but can cause formatting issues on Windows, which expects \r\n (CR-LF).
I guess I should really have asked: Is this something that’s normal when esphome’s running separately on windows?
It’s not like its a huge problem, but if it isn’t expected when its both running on and being accessed from windows then it’d be good to figure out why.
I run esphome on Windows that I installed using the following:
pip install pipx
pipx install esphome
This is not the way it is suggested in the esphome docs. Python is complicated and has a poor story for virtual environments. pipx makes it reasonably easy. uv is the up and coming (possibly) better solution, but probably best treated as experimental right now.
Note that you will need to uninstall esphome or start with a clean system to use the method I listed.
Thanks.
I’m not the most familiar with python, the various ways it can run and that things can be installed, so I uninstalled python completely and manually removed anything left in program files and the build folder.
Reinstalled it and ran those two commands… Got a small esphome project building right now and still see this:
In March 2025 I installed Windows 11 and updated to then current updates.
Installed Python 3.13.2 from here (.3 is current)
64-bit installer
I also install VS Code and typically use esphome from its terminal. I also install Windows Terminal and use it.
Your pictures show the code doesn’t know what size terminal you have or how to control it properly. It wasn’t obvious to me what library esphome is using for its TUI, but it does appear confused.
