Workday binary sensor "This device cannot be added from the UI"
As per title.
There isn’t anything on the workday page to help with manual YAML install, so I don’t know how to proceed.
Also, can someone advise why I’m getting this?
My HA setup is on a rPi version 2023.2.5
This was moved to the UI in version 2023.5, see: 2023.5: Let's talk! - Home Assistant
You need to update.
Ah, thanks so much. I thought I had checked for updates.
It says “No updates available” in Settings > System > Updates
I’ll go and see how to manually update
Hmm, don’t think I can manually update as I’m on HASSIO
I guess I have to wait for it to be released.
What version number of HA (Core) are you on?
2023.5 (and .6, .7, .8, .9, and .10) have all been released and are available for Home Assistant OS (which is what hassio has been called for the last 3 years).
This was released in February:
As Tinkerer said, an update has been released every month since then.
Check your logs and system repairs for messages about your inability to update.
Thanks, I’ll check that and come back if I get stuck.
