Workflow for automating old amp etc
I’m a beginner and struggling with some basics.
I have created a script that turns off my amp using Broadlink Rm 4 Pro
I’ve then got a button that can run that script
That works
However I can see I could also potentially run the command straight from the button? Ie not use ascript
Is running the script the best method though?
If I then went to run a whole series of things…eg turn on projector…turn on amp…delay… Charge input etc
Would I create scripts for all the individual things (eg power on amp, power on Blu-ray) and then nest those scripts inside one large script that automates all these things?
Thanks for any clarification!
If you want to use a series of actions then one single script is the way to do it.
Agree. Yes it is.
