Hello community
after rel. long research I have a running media-player config without anny jitter and stuff.
esphome:
friendly_name: Speaker4
esp32:
board: esp32-s3-devkitc-1
framework:
type: esp-idf
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: ""
ota:
- platform: esphome
password: ""
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Speaker4 Fallback Hotspot"
password: ""
captive_portal:
web_server:
port: 80
version: 3
switch:
- platform: gpio
pin:
number: GPIO47
inverted: False
i2s_audio:
- i2s_lrclk_pin: GPIO6
i2s_bclk_pin: GPIO5
speaker:
- platform: i2s_audio
dac_type: external
i2s_dout_pin: GPIO07
channel: stereo
bits_per_sample: 32bit
i2s_audio_id: i2s_audio_speaker
timeout: never
buffer_duration: 100ms
sample_rate: 48000
- platform: mixer
output_speaker: myspeaker
num_channels: 2
source_speakers:
- id: announcement_mixing_input
timeout: never
- id: media_mixing_input
timeout: never
- platform: resampler
output_speaker: announcement_mixing_input
sample_rate: 48000
bits_per_sample: 16
output_speaker: media_mixing_input
sample_rate: 48000
bits_per_sample: 16
media_player:
- platform: speaker
internal: False
volume_increment: 0.05
volume_min: 0.4
volume_max: 0.85
announcement_pipeline:
speaker: announcement_resampling_speaker
format: FLAC # FLAC is the least processor intensive codec
num_channels: 1 # Stereo audio is unnecessary for announcements
sample_rate: 48000
media_pipeline:
speaker: media_resampling_speaker
num_channels: 2
sample_rate: 48000
on_announcement:
- mixer_speaker.apply_ducking:
decibel_reduction: 20
duration: 0.0s
playing streams (of internet-radio-stations) absolutely works, but I have to send the media-url with homeassistant. and thats not the optimum. now I wanted to give the select-component a try, but that doesn’t compile
here is my select:
select:
options:
- "Ö3" # https://ors-sn03.ors-shoutcast.at/oe3-q1a
- "Ö1" # https://orf-live.ors-shoutcast.at/oe1-q2a
- "Radio-ST" # https://ors-sn08.ors-shoutcast.at/stm-q1a
- "FM4" # https://orf-live.ors-shoutcast.at/fm4-q2a
- "ClassicRadio" # https://ice-sov.musicradio.com/ClassicFMMP3
- "Radio Paradise"
optimistic: true
on_value:
then:
- lambda: |-
if (id(radio_preset).state == "FM4") {
id(external_media_player).play_media("https://orf-live.ors-shoutcast.at/fm4-q2a");
} else if (id(radio_preset).state == "Ö1") {
id(external_media_player).play_media("https://orf-live.ors-shoutcast.at/oe1-q2a");
} else if (id(radio_preset).state == "Radio-ST") {
id(external_media_player).play_media("https://ors-sn08.ors-shoutcast.at/stm-q1a");
} else if (id(radio_preset).state == "Ö3") {
id(external_media_player).play_media("https://ors-sn03.ors-shoutcast.at/oe3-q1a");
I am quite ssure, that anybody has already done that succesfully
regards
peter
