Working on Mobile Dashboard and having issues with spacing
I’m working on a dashboard for mobile phones and am having issues with spacing that is driving me crazy. It seems when I use the Vertical Stack In Card I get different results on the spacing of the different cards.
For example, I’m trying to include Mushroom Title cards in each grouping of my devices. For my Alarm System and Door Locks that works fine and the spacing looks normal, but for my door contacts it puts each entity on top of each other with no spacing between each. I want it to look like my window group entities, but with the title like it is in the door group. Any ideas on how to do this? Here is the yaml for my door group card.
Thanks!
type: custom:vertical-stack-in-card
cards:
  - type: custom:mushroom-title-card
    title: Doors
    subtitle: ""
    title_tap_action:
      action: none
    subtitle_tap_action:
      action: none
  - type: horizontal-stack
    cards:
        primary: Front Door
        secondary: |-
          {% if is_state('binary_sensor.front_door_contact_template', 'off') %}
            Closed
          {% elif is_state('binary_sensor.front_door_contact_template', 'on') %}
            Open
          {% else %}
          {{ states('binary_sensor.front_door_contact_template') }}
          {% endif %}
        icon: >-
          mdi:door
          {% elif is_state('binary_sensor.front_door_contact_template', 'on' )
          mdi:door-open
          {% else %}
          mdi:help-circle
          {% endif %}
        entity: binary_sensor.front_door_contact_template
        icon_color: >-
          {% if is_state('binary_sensor.front_door_contact_template', 'off' ) %}
          green
          red
          {% else %}
          orange
          {% endif %}
        layout: horizontal
        tap_action:
          action: more-info
        hold_action:
          action: none
        double_tap_action:
          action: none
        primary: Garage Door
        secondary: >-
          {% if is_state('binary_sensor.mudroom_door_contact_template', 'off')
            Closed
          {% elif is_state('binary_sensor.mudroom_door_contact_template', 'on')
            Open
          {% else %}
          {{ states('binary_sensor.mudroom_door_contact_template') }}
          {% endif %}
        icon: >-
          mdi:door
          {% elif is_state('binary_sensor.mudroom_door_contact_template', 'on' )
          mdi:door-open
          {% else %}
          mdi:help-circle
          {% endif %}
        entity: binary_sensor.mudroom_door_contact_template
        icon_color: >-
          {% if is_state('binary_sensor.mudroom_door_contact_template', 'off' )
          green
          red
          {% else %}
          orange
          {% endif %}
        layout: horizontal
        tap_action:
          action: more-info
        hold_action:
          action: none
        double_tap_action:
          action: none
    cards:
        primary: Deck Door
        secondary: |-
          {% if is_state('binary_sensor.deck_door_contact_template', 'off') %}
            Closed
          {% elif is_state('binary_sensor.deck_door_contact_template', 'on') %}
            Open
          {% else %}
          {{ states('binary_sensor.deck_door_contact_template') }}
          {% endif %}
        icon: |-
          mdi:door
          {% elif is_state('binary_sensor.deck_door_contact_template', 'on' ) %}
          mdi:door-open
          {% else %}
          mdi:help-circle
          {% endif %}
        entity: binary_sensor.deck_door_contact_template
        icon_color: |-
          {% if is_state('binary_sensor.deck_door_contact_template', 'off' ) %}
          green
          red
          {% else %}
          orange
          {% endif %}
        layout: horizontal
        tap_action:
          action: more-info
        hold_action:
          action: none
        double_tap_action:
          action: none
        primary: Basement Door
        secondary: >-
          {% if is_state('binary_sensor.basement_door_contact_template', 'off')
            Closed
          {% elif is_state('binary_sensor.basement_door_contact_template', 'on')
            Open
          {% else %}
          {{ states('binary_sensor.basement_door_contact_template') }}
          {% endif %}
        icon: >-
          mdi:door
          mdi:door-open
          {% else %}
          mdi:help-circle
          {% endif %}
        entity: binary_sensor.basement_door_contact_template
        icon_color: >-
          {% if is_state('binary_sensor.basement_door_contact_template', 'off' )
          green
          red
          {% else %}
          orange
          {% endif %}
        layout: horizontal
        tap_action:
          action: more-info
        hold_action:
          action: none
        double_tap_action:
          action: none
    cards:
        primary: Single Garage Door
        secondary: >-
          Hold to Operate:
          {% if is_state('binary_sensor.aqara_contact_garage_door_single',
          'off') %}
            Closed
          {% elif is_state('binary_sensor.aqara_contact_garage_door_single',
          'on') %}
            Open
          {% else %}
          {{ states('binary_sensor.aqara_contact_garage_door_single') }}
          {% endif %}
        icon: >-
          'off') %}
          mdi:garage
          'on' ) %}
          mdi:garage-open
          {% else %}
          mdi:help-circle
          {% endif %}
        entity: binary_sensor.aqara_contact_garage_door_single
        icon_color: >-
          {% if is_state('binary_sensor.aqara_contact_garage_door_single', 'off'
          green
          'on' ) %}
          red
          {% else %}
          orange
          {% endif %}
        layout: horizontal
        tap_action:
          action: more-info
        hold_action:
          action: call-service
          service: switch.turn_on
            entity_id: switch.single_garage_door_relay
          data: {}
        double_tap_action:
          action: none
        multiline_secondary: false
        primary: Double Garage Door
        secondary: >-
          Hold to Operate:
          {% if is_state('binary_sensor.aqara_contact_garage_door_double',
          'off') %}
            Closed
          {% elif is_state('binary_sensor.aqara_contact_garage_door_double',
          'on') %}
            Open
          {% else %}
          {{ states('binary_sensor.aqara_contact_garage_door_double') }}
          {% endif %}
        icon: >-
          'off') %}
          mdi:garage-variant
          'on' ) %}
          mdi:garage-open-variant
          {% else %}
          mdi:help-circle
          {% endif %}
        entity: binary_sensor.aqara_contact_garage_door_double
        icon_color: >-
          {% if is_state('binary_sensor.aqara_contact_garage_door_double', 'off'
          green
          'on' ) %}
          red
          {% else %}
          orange
          {% endif %}
        layout: horizontal
        tap_action:
          action: more-info
        hold_action:
            entity_id: switch.double_garage_door_relay
          data: {}
        double_tap_action:
          action: none
use grid card instead of horizontal. set to 2 columns and square false
I tried a grid card on the “Alarm Relays” group. Now the entities don’t take up the whole horizontal space and there is still no vertical padding between them and the end of the Vertical Stack in Card.
type: vertical-stack
cards:
    title: Hello, {{ user }} !
  - square: false
    type: grid
    cards:
        primary: Hello, {{user}}
        secondary: How are you?
        icon: mdi:home
        icon: mdi:home
        icon: mdi:home
        icon: mdi:home
        icon: mdi:home
        icon: mdi:home
    columns: 2
with custom vertical stack card
First, thank you for the help, I appreciate it. But that still isn’t quite what I’m looking for. In your last image, that is spot on, except there is no padding/spacing below the very last row of the grid.
Well, then use custom layout card…
