Would like my tablet turning off after some time while showing a camera live stream
Following scenario, I would like to have:
  1. Someone rings the doorbell
  2. Tablet screen turns on, shows the live stream of the doorbell camera
  3. After about 10 seconds it turns off
I already managed to let my tablet turning on using
  - action: notify.mobile_app_t20mini_eg
      message: command_screen_on
However, when the tablet shows the camera image in the HomeAssistant app or my camera app (reolink), the screen wont turn off automatically.
How can I let the screen turn off, although it shows a camera stream? The screen automatically turns off, if there is no app open, but it seems, that the camera stream does not let the tablet turning the screen off automatically.
I tried message: command_screen_off, but this does not work.
Any ideas?
From the docs: use command_screen_off_timeout
I think, this command only sets the timeout to turn off the screen. I already set this to 15 seconds in the android system. However, this timeout is not used, if the camera stream is active. It is a timeout for inactivity.
Good day.
Tell me, did you manage to solve this problem somehow?
I also encountered the problem that the tablet screen does not turn off if there is a live stream from the camera on the screen. In the system settings of the tablet, the tablet shutdown period is set to 15 seconds, but this does not help.
Hello, I solved it by using fully kiosk app.
