Please post in English as a common language in forum.
I’m new here and would like to set up a smart home system in an ideal environment. Currently, there’s only Wi-Fi in the building.
System/Functions:
EnOcean light switches - NodOn or Eltako
Lighting actuator - Shelly
Heating thermostat - Shelly
Temperature sensor - ?
Humidity sensors - Shelly
Window contacts - ?
What’s needed to integrate such a system? Is it possible using Home Assistant Green?
It is. But what do you want in the future?
The oboard Shelly integration works very well. Which brand these sensors for temperature or windows contacts are? Zigbee? Zwave? Wifi?
EnOcean (EnOcean - Home Assistant)
Shelly (Shelly - Home Assistant)
If want to use the german forum, you take the forum of Simon42 in a parallel way. Here please only in english
I’m also from Germany → deepL helps you.
no problem to use English, but why am I e
excluded here?
Where can I found the Forum from Simon42?
Thanks for answer, I will prefer to use Wifi.
Which brand?
