Write JSON to file for events log
Hello there, I am trying to implement a basic events log to have a log of the last 8 events that I manually choose to display through with my automations and to show them in the Lovelace dashboard.
Until today I used an input_select helper: every element in the list was an event like title|subtitle|date|color|icon and then I used jinjia in Lovelace to extract every variable. A script help me write new events and deleting the old one, in the list. That worked but every Home Assistant restart, every element in the list was reset to their default one.
I then decided to shift to a JSON based approach. Using a file where I can write the events and retrieve it.
The reading works like that:
command_line:
  - sensor:
      command: 'cat /config/www/event_log.json'
      name: 'Last events list'
      icon: mdi:history
      unique_id: logbook_json
      scan_interval: 10
      json_attributes:
        - events
      value_template: '"OK"'
But I cannot make the “writing” part work. For the writing, I am using a shell_command action with jq:
shell_command:
  log_event: >-
    jq --argjson new_event '{{ new_event }}' '.events = [$new_event] + .events[:7]' /config/www/event_log.json > /config/www/event_log.tmp && mv /config/www/event_log.tmp /config/www/event_log.json
If I execute it in the terminal, with an example JSON text, it works perfectly. It doesn’t work if I use it within my script:
fields:
  title:
    name: Title of the event
    required: true
    selector:
      text:
        multiline: false
        type: text
  subtitle:
    name: Text (one line) of the event
    required: false
    selector:
      text:
        multiline: true
        type: text
  icon:
    name: Icon to show
    required: false
    selector:
      icon: null
  color:
    name: Color of the icon
    required: false
    selector:
      text:
        multiline: false
        type: text
sequence:
  - variables:
      new_event:
        title: "{{ title }}"
        subtitle: "{{ subtitle }}"
        date: "{{ now() }}"
        icon: "{{ icon if icon is not none else 'mdi:information' }}"
        color: "{{ color if color is not none else 'blue' }}"
  - action: shell_command.log_event
      new_event: "{{ new_event }}"
mode: queued
icon: mdi:tooltip-plus-outline
max: 5
I think there is a mismatch between how the script passes the new_event variable to the shell_command and how jq expects this JSON text… but I am not able to debug it.
Can you help me with that?
