I’m using hass.io. After some automations didn’t work as expected I discovered the system time is incorrect.
If added the date time sensor in the front end and it is showing 16:56 while the time on my pc is 19.28. I tried the date command over ssh and it’s also showing the wrong time. Timezone is correct. Date -s returns “Can’t set date: operation not permitted”.
How do I set the system time?
How do I check and activate synchonisation with ntp-server?
other relevant information may be:
- I’m using duckdns with ssl
- I’ve my router configured to forward port 443 to 8123
