I have some problems with HA ( last version) maybe also older versions
I was kicked out at HA on my laptop , but i still was logged in at smartphone
but at some reason the 2-steps check did not work
So i check the at sensors , an the time at sensors (switched ON/OFF)is different then local time?
When i check at time zone(Setting> System>General) , it is correct (GMT+1h Amsterdam).
Also at account Time format is OK.
But when i switch a sensor the time is different it is 1h and 30min behind local time ???
When i do a “time_utc’” it is also 1h and 30 min behind local time
When i check at Terminal it is also the wrong date
i also restored some older backups, for network but same issue
im running HA at a PI4
Home Assistant 2023.2.5
Supervisor 2023.01.1
Operating System 9.5
Frontend 20230202.0 - latest
