I have completely wrong dates and times in HA.
Home Assistant thinks it is February 2nd, where it is June 13th. The following template
{{as_local(states.sensor.time.last_updated).strftime('%A %d.%m.%Y %H:%M')}}
returns
Last updated shows 19 weeks ago when toggle the boolean or start the timer:
Supervisor (and core) logs are yesterday, time is off.
21-06-12 20:36:17 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-06-12 20:36:17 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-06-12 20:36:17 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-06-12 20:36:17 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-06-12 20:36:17 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-06-12 20:36:18 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-06-12 20:36:18 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-06-12 20:36:18 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-06-12 20:39:05 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-06-12 20:44:40 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-06-12 21:11:01 WARNING (MainThread) [supervisor.addons.options] Option 'anonymous' does not exist in the schema for Mosquitto broker (core_mosquitto)
21-06-12 21:14:50 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
Rebooted several times, no change.
Changed Configuration/General Conifg/Time Zone to different location and back, no change.
I was playing around with automations and blueprints before this happend.
Any ideas?
Core log
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
2021-06-11 23:10:16 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-06-11 23:10:16 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration rki_covid which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-06-11 23:10:37 WARNING (MainThread) [homeassistant.setup] Setup of rki_covid is taking over 10 seconds.
2021-06-11 23:10:37 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2021-06-11 23:10:37 WARNING (MainThread) [homeassistant.components.scene] Setup of scene platform homeassistant is taking over 10 seconds.
2021-06-11 23:10:37 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2021-06-11 23:10:38 WARNING (MainThread) [homeassistant.setup] Setup of timer is taking over 10 seconds.
2021-06-11 23:10:49 WARNING (MainThread) [homeassistant.components.switch] Setup of switch platform adguard is taking over 10 seconds.
2021-06-11 23:10:51 WARNING (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for None (192.168.88.34): Error connecting to ('192.168.88.34', 6053): [Errno 113] Connect call failed ('192.168.88.34', 6053)
2021-06-11 23:10:55 WARNING (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for None (192.168.88.19): Error connecting to ('192.168.88.19', 6053): [Errno 113] Connect call failed ('192.168.88.19', 6053)
2021-06-11 23:10:55 WARNING (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for None (192.168.88.13): Error connecting to ('192.168.88.13', 6053): [Errno 113] Connect call failed ('192.168.88.13', 6053)
2021-06-11 23:10:55 WARNING (MainThread) [homeassistant.components.esphome] Can't connect to ESPHome API for None (192.168.88.18): Error connecting to ('192.168.88.18', 6053): [Errno 113] Connect call failed ('192.168.88.18', 6053)
2021-06-11 23:12:31 ERROR (MainThread) [homeassistant.components.switch] Platform esphome does not generate unique IDs. ID tuyasteckdose1switchgosund_plug_1 already exists - ignoring switch.gosund_plug_1
2021-06-11 23:12:31 ERROR (MainThread) [homeassistant.components.sensor] Platform esphome does not generate unique IDs. ID tuyasteckdose1sensorgosund_plug_1_voltage already exists - ignoring sensor.gosund_plug_1_voltage
2021-06-11 23:12:31 ERROR (MainThread) [homeassistant.components.sensor] Platform esphome does not generate unique IDs. ID tuyasteckdose1sensorgosund_plug_1_current already exists - ignoring sensor.gosund_plug_1_current
2021-06-11 23:12:31 ERROR (MainThread) [homeassistant.components.sensor] Platform esphome does not generate unique IDs. ID tuyasteckdose1sensorgosund_plug_1_wattage already exists - ignoring sensor.gosund_plug_1_wattage
2021-06-11 23:12:31 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform esphome does not generate unique IDs. ID tuyasteckdose1binary_sensorgosund_plug_1_power_button already exists - ignoring binary_sensor.gosund_plug_1_power_button
2021-06-12 00:05:35 ERROR (Thread-24) [homeassistant.helpers.template] Template variable error: 'trigger' is undefined when rendering '{## Imitate available variables: ##}
2021-06-12 18:44:18 ERROR (MainThread) [frontend.js.latest.202106030] :0:0 Script error.
2021-06-12 21:37:59 WARNING (MainThread) [homeassistant.components.fan] The fan.set_speed service is deprecated, use fan.set_percentage or fan.set_preset_mode instead
