Wrong time in Home Assistant
I’m running HA on a Raspberry Pi 3 with HASSIO.
For some reason my Home Assistant time is 35 minutes behind.
If I press a switch, in the logbook it instantly displays it as 35min ago.
The time zone is correct (GMT -03:00 São Paulo).
Why could this be happening and how to fix it?
Update: I don’t know if it may be related, but I have a Cloudflare tunnel installed with the Cloudflared addon. Although the problem persists even when connected to HA through my local address.
Thank you
Try rebooting the Host (not restarting Home Assistant).
Also it has not been called HASSIO for at least 3 years. Home Assistant OS. Or HA OS for short.
Thank you. I didn’t know this option existed - I thought restarting Home Assistant would reboot the device.
Yesterday I installed the Chromy addon as a workaround and it worked, but wanted a “native solution”.
Today I’ve uninstalled Chromy and just rebooted as you said and it still shows the correct time.
Thank you vey much
Thanks Tom! I was having this problem and your solution worked (of course). Thank you again
