Wrong UTC time
Hello! I’m having trouble with HA “time”. I press a switch and it instantly shows “pressed 35 minutes ago.” It’s as if the time is 35 minutes behind.
When I type {{utcnow()}} it shows me the time back the same 35 minutes.
Shows me “18:25” when the UTC is 19:00.
How can I make HA get the time correctly? I have a HA Green.
Thank you.
Settings > System > General
Check you have correctly set the Time Zone in there.
The solution was install the “chrony” add-on.
Thanks!
