pls help!
i use the following tempate in “Tools” to export all entities i have for external analyses.
but now i can´t do it at once, because it´s to much output size?
i have solved this prob for me to skip the “area”, then it worked! now i have to do two exports and then combine them in excel, but this is anoying. edit: not even without area it doesn´t work. then there no instant error, but output in tools is endlessly idling…
is there a chance to extend the output size, or any other technique to export that metadata into any file?
thanx in advance
br Frank
## alle Entities mit Areas etc.
## ALLE Devices mit zusatzinformationen (ACHTUNG: dauert! ewig!...nö geht relativ schnell? 2025-07-05)
## von ComunityUser Taras , ohne leerzeichen am Anfang nd model ID separat!
Entity ID;Device;Domain;Manufacturer;Model;Model ID;Area;Integration;ID
{% for s in states -%}
{%- set identifiers = (device_attr(s.entity_id, 'identifiers') | default([], true)) | first | default([], true) -%}
{%- set integration = identifiers[0] | default('-', true) -%}
{%- set unique_id = identifiers[1] | default('-', true) -%}
{%- set manufacturer = device_attr(s.entity_id, 'manufacturer') | default('-', true) -%}
{%- set model = device_attr(s.entity_id, 'model') | default('-', true) -%}
{%- set model_id = device_attr(s.entity_id, 'model_id') | default('-', true) -%}
{%- set area = device_attr(s.entity_id, 'area_id') | default('-', true) -%}
{{s.entity_id}};{{s.name}};{{s.domain}};{{manufacturer}};{{model}};{{model_id}};{{area_name(area)}};{{integration}};{{unique_id}}
{% endfor %}
Grab a copy of the core.entity_registry from the hidden .storage folder & paste it into excel. You can remove the first few lines which will allow you to change the csv into proper excel columns
hi @Didgeridrew thanx
no not really sorry
as a non developer i like the word “just” in your comment
i would need a patient teacher for simply starting with that topic at all.
but i put it on my bucket list as i´m interested in learning to use APIs…
thanx for your comment.
i take a look into ‘entity_registry’ file. it seems “column names” are besides the values, what would make it a little bit complicated for my needs?
now i build me a short workaround with two separated template calls, what results i´m copying into my existing excel, where this is “merged” via XLOCKUPs.
i used that to clean up some template errors and added a tabulator separator, what makes simply copy&paste into excel much more convenient.
but thank for that, good to know where the central entity files is!
i need it regularly, but just from time to time to check my influxbd and mariadb exclusions and continious_querys.
currently because my both databases size(s) have “exploded” over the last two weeks
