Yeah but your screenshot shows only 4 sections can fit.
If you want more columns, you need to decrease the size of the sections. That’s all manual
Right. I want 5 or 6 sections wide. It’s a 32" screen. Can I make that happen using sections? Maybe I’m just missing something.
Click on each new section and adjust the size. I believe it’s under one of the tabs. Worse case is you have to adjust it in yaml.
When I edit the section it shows a width of 1. I can make it wider but not narrower. Do you know how to do it in YAML?
There’s a setting somewhere that ends up being a fraction, you can change that. I don’t remember where I found it as it’s been a couple of months. As for yaml, just change that setting, swap to yaml and alter the values.
Edit: it’s a yaml only setting, I don’t read frontend code so it’s likely in the docs.
Edit edit, it’s on each card
Well I added column_span: 0.5 to each section and now my tablet only shows 3 and my desktop only shows 4 sections across. Not what I expected.
my “workaround”:
using lovelace-global-mod, I edited a new template to zoom out, making a column more available.
add this to the template file:
Theme name:
zoom-drawer-selector: "home-assistant-main"
zoom-drawer-style: |
home-assistant-main {
zoom: 0.93;
relaod with service call “Home Assistant Frontend: Reload themes”
and then change the theme for a user/device.
