Like many other people I have automations based on anyone being home or not.
I think it would be helpful if this was created out the box so there is an anyone home binary sensor (possibly based on number of people in home zone > 0).
This would avoid people needing to get into templating or creating yaml groups to achieve this.
Possibly extending this would be to have a condition under time and location of anyone home so you can just select that as a condition
Indeed it is but to use it as a condition in an automation you need to select a numerical condition and select zone.home entity and then do greater than 0 which isn’t the clearest for newcomers.
People can argue what is clear and not clear forever and more.
As I see it there is a way to do it that is documented.
Even if this is implemented someone will argue a green/red light is better.
If this is the requirements then the current solution meets them.
No groups, templates or yaml is needed
