TL;DR: We don’t have actions called switch.turn_off_switch
or light.turn_on_light
, so we shouldn’t have actions called things like cover.open_cover
or cover.close_cover
There are a small number of action names that repeat their domain name as a noun within the action name. I reviewed the actions for every domain listed in the HA docs and these are the only ones that reuse the domain name in the action name as a noun:
alarm.alarm_arm_MODE [home, away, night, vacation, custom_bypass]
alarm.alarm_disarm
alarm.alarm_trigger
cover.[open|close]_cover
cover.toggle
cover.[open|close]_cover_tilt
cover.toggle_tilt
lawn_mower.start_mowing
lawn_mower.pause
lawn_mower.dock
Instead, I think these actions should be named:
alarm.arm_MODE [home, away, night, vacation, custom_bypass]
alarm.disarm
alarm.trigger
cover.[open|close]
cover.toggle
cover.[open|close]_tilt
cover.toggle_tilt
lawn_mower.start
lawn_mower.pause
lawn_mower.dock
This one is borderline, but you could argue “select” is a verb in the action name:
select.select_[first,last,next,option]
I excluded these two domains because you could write a WTH about them alone:
media_player
notify
(Side note: Someone please write a WTH about how confusing it is that media_player.play_media
and media_player.media_play
do different things)
Finally, here are all the other domains’ actions. None of these include the domain as a noun in their action names.
button.press
calendar.VERB_event(s) [create, get]
camera.[dis|en]able_motion_detection
camera.play_stream
camera.VERB [record, snapshot]
camera.turn_[off|on]
climate.set_ATTRIBUTE [aux_heat, preset_mode, temperature, humidity, fan_mode, hvac_mode, swing_mode, swing_horizontal_angle]
climate.turn_[off|on]
date.set_value
datetime.set_value
device_tracker.see
fan.set_ATTRIBUTE [percentage, preset_mode, direction]
fan.turn[off|on]
fan.toggle
fan.[in|de]crease_speed
fan.oscilate
humidifier.set_ATTRIBUTE [mode, humidity]
humidifier.turn_[off|on]
humidifier.toggle
image.snapshot
light.turn_[off|on]
light.toggle
lock.VERB [lock, unlock, open]
number.set_value
remote.turn_[off|on]
remote.toggle
remote.send_command
scene.turn_on
scene.VERB [apply, create, delete]
siren.turn_[off|on]
siren.toggle
switch.turn_[off|on]
switch.toggle
text.set_value
time.set_value
todo.VERB_NOUN [get_items, add_item, update_item, remove_item, remove_completed_items]
