I see that the Home Assistant staff are using a new standard for CPU/RAM usage that they are not sharing with the rest of use. I don’t see why the System Monitor integration can’t be updated to report in the potato scale. If this has not yet been formalized, I would suggest referencing this chart of potato sizes:
(sort by max size for best guidance)
and use this scale:
CPU/RAM usage between 0 - 15% would report back Chiquilla Pitiquiña.
between 16 - 30% would be Calawah
between 31% - 45% would be Kinda Llumpy
between 46% - 60% would be German Butterball
between 61% - 75% would be To-Le-Ak
between 75% - 90% would be Rozette
above 90% should report Add Another Potato
I would rather have a more generic “X as Potato” helper, with a proper device_class to give the right graphic presentation.It would suport many more uses.
Are those highly available potatoes? Potato cluster?
How many eyes can each cluster support?
Do they run better mashed? Broiled? BAKED?
Is a twice baked potato a virtual potato or a container of potato?
Potatoes can be containerized quite well. If you want the containers integrated in Home Asssistant you obviously need a Smart container (with sufficient ventilation to prevent potatoes overheating):
