This is annoying as when I try to find all the places some entities are used, I must go through all automations and helpers.
Some templates may use entities in an implicit way (referring whole domains, referring entities with dynamically composed entity_ids, …).
Means:
- a list of entities may be TOO long
- a list of entities may be dynamic and keep changing in a background while a user is staring at “Related entities” UI.
I don’t expect wildcards to show in “linked”, but I have several example of input_number or input_datetime clearly used in automation, with no link:
- data:
hvac_mode: heat
temperature: "{{ states('input_number.consigne_chauffage')| float(0) }}"
entity_id: climate.clim_rdc
action: climate.set_temperature
- condition: template
value_template: >-
{{ (now().strftime('%Y-%m-%d') >=
states('input_datetime.depart_vacances')) and
(now().strftime('%Y-%m-%d') <
states('input_datetime.retour_vacances')) }}
And it’s not because they are helpers, as this one is correctly detected:
- action: input_select.select_option
metadata: {}
option: Extérieur
entity_id: input_select.mode_vacances
I have similar examples when a helper which is used in an automation is not listed as “relative”. Not sure then if it is a bug or by a design.
(honestly, not using this “relative” feature myself)
