WTH is it so hard to setup schedules / timers?
I use helper switches to turn on/off reminders about “you need to vacuum, you need to take out the trash” etc.
Those run on a timer, which gets reset with every reload.
persistent timers (for example set the current date/time +3 days) would be great.
these should be able to be changed aswell, so if i take out the trash and reset the switch, it should use the current date/time and add 3 days.
Currently this is way too much work to setup with multiple helpers and tons of automations, especially if you use this for every chore at home.
Remember to vote for your own post
Have you tried this instead?
I use it to help automate my irrigation, robot vacuums and heating.
I’m confused - isn’t this what the “restore” option does (assuming it doesn’t finish when HA is down)? But I’d be using Calendar and/or To-Do items instead. For example I have a birthday calendar and on a birthday I create a to-do item that keeps nagging me until I close the item. I also use the chores feature in the Grocy addon - this is good for things that should be x weeks apart but you’re not very good on doing them on the right day.
