I’m really glad that I don’t need to use github for this.
My problem is, that the RFLink integration just doesn’t work on my Home Assistant instance. I use the latest version, and probably I don’t plan to revert to older version (I’m not exactly a power user).
The log shows me this:
Napló: homeassistant.components.rflink
Forrás: components/rflink/__init__.py:247
integráció: RFLink (dokumentáció, problémák)
Először fordult elő: 07:00:34 (2722 Események)
Utoljára naplózva: 14:35:35
Error connecting to Rflink, reconnecting in 10
File "/usr/src/homeassistant/homeassistant/components/rflink/__init__.py", line 247, in connect
transport, protocol = await connection
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 1155, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 1137, in create_connection
sock = await self._connect_sock(
exceptions, addrinfo, laddr_infos)
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 1040, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.13/asyncio/selector_events.py", line 641, in sock_connect
return await fut
File "/usr/local/lib/python3.13/asyncio/selector_events.py", line 681, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
ConnectionRefusedError: [Errno 111] Connect call failed ('<IP OF THE RFLINK>', <PORT>)
I tried everything to make it work, with no success. I got an RFLink PRO from nodoshop, the ESP32 module runs ESPeasy, on that side I don’t see any problem, however, it was a real pain to configure…
Thank you for the help!
