WTH, searching in Select Selectors
In most of the Blueprint/Config Flow dropdown selectors, you can type in letters to filter the results to more easily find the option you want. For Select Selectors, unless you allow Custom Values, you can’t search. That makes finding the item you want much harder if the list is long.
https://design.home-assistant.io/#components/ha-selector
