WTH - Temperature always changes back to Fahrenheit after every reboot
Every time I reboot home assistant the temperature readings always change to F even though in the settings it’s still set as C. After each reboot I need to change to F, save, then change back to C. Every time! If this could please be fixed that would be amazing! Thanks.
This is likely an issue with the integration providing your temperature entities, can you please revise your wth with that information? This is not normal behavior, most integrations retain units over reboots and restarts
Thanks for the reply. The only thing I’m currently using is a Nest thermostat, this is what I’m having issue with the readings. The device shows up as C, so I’m not sure what I would change on the Nest end.
