The MQTT number integration is only handling decimals and not time. Meaning when you handle minutes you can’t control hours. For example 120 minutes as a number to 2h in the GUI (02:00).
When you set increments as well to handle hours, if you go outside of 60 minutes the value is outside of the accepted range because 61 minutes is possible.
