WTH Why is not all integration reloadable?
The title says it all. The UI defined integrations are reloadable by default, but file defined ones are just early have these options. This is really annoying with integrations that receives white/blacklists, for example Prometheus and Influxdb integration. When I add a new device I need to restart HA to pick up the new configuration.
And while we are her I want to mention that, with the newly introduced integration UI where the file defined ones are listed as well, why we still have the old reload UI under development section, IMO this integration reloads should moved to the new UI as well.
Sorry, what do you mean by “old reload UI under development section”?
The “Yaml” tab under “Development tools”. It’s basically reload functionality plus one more button to validate all the configuration
Sorry again - what “reloads functionality”?
Do you mean a particular entry like
And are you trying to say that this UI should have a button “Reload”
instead of that “command line entities” line on a previous screenshot?
Note that “Settings → Integrations” page does not include “panes” for many integrations like “input_boolean”, “automations” - which have corr. entries on “Dev tools → yaml” page to reload these automations.
Also, some integrations like “netdata” seems to have no possibility to be reloaded w/o restarting HA (you may select “all yaml configuration” entry and see that it does not reload some yaml-defined integrations).
