WTH why is there no easy UI to setup hardware switches
Blueprints should be enhanced to provide a straightforward way to visually configure hardware switches similar to the custom integration “Switch Manager”. There you have a picture of the switch, can select the button you wish to edit and then get the available events for that button where you can add your actions. When you press the button on the hardware switch, the corresponding button in the user interface lights up.
This way has a significantly improved UX for beginners and is much neater than a lengthy list of events and actions in a standard blueprint.
