Hello!
i’m using the wundergroundpws integration to get wheater data into home assistant. the values are correct, but it shows “clear night”, but it’s 3 pm atm and the sun in shining. does “clear night” come from wunderground or does this come from “something else”?
if i open the detail for my wheater station i get this:
If it’s on your dashboard, it’s probably coming from the default weather provider that comes with every install. That card should be switched to point to the wunderground integration.
Also if you’re seeing clear night in the middle of the day, I’d check home zone location & timezone in HA. Wouldn’t be the first time here someone blindly clicked Next on onboarding & left their location in Amsterdam (default)
it was probably coming from the default weather provider. i’m a little confused with all the weater providers. i get data in the cards, but i can’t find the entities in developer tools
i’ll open another thread for that.
location / timezone is correct (and it’s the same as amsterdam anyway).
