Wyoming Protocol - After updating to HA 2025.5.4 upwards
Wyoming Protocol has been identified as causing OOM issues (possibly others) upon upgrading to Home Assistant 2025.5.4.
Same thing on 2026.6.0.
Should I go for 2026.6.1 ?
I cannot disable Wyoming Protocol as I need it to run my local ESP32 voice command boxes.
Would anyone happen to know if this issue has been resolved please? Or whether there is a proper fix in the pipeline?
Kindly see: Memory leak when Assist Microphone addon is running with Wyoming integration on HA Core 2026.4.3 · Issue #168653 · home-assistant/core · GitHub
and Wyoming Protocol / Assist Microphone leaking memory since last HA Core (2026.4) or possibly HA OS (17.2) update · Issue #167971 · home-assistant/core · GitHub
I do not need Assist Microphone - but definitely need Wyoming Protocol. My question is - would running only Wyoming Protocol still wreak the same havoc?
Until this is settled, I have to stick to HA 2025.5.1 :(((
Thanks everything
Problem still not resolved by HA 2026.6.2 :(((
It seems that with every change log, this Assitant Microphone + Wyoming Protocol issue is not mentioned as having been addressed.
Can someone PLEASE help? I can never upgrade HA at this rate.
Could someone check this please? It has not been resolved yet. I tried to upgrade to HA 2026.6.2 and had to roll-back.
Issue appears to have something to do with Assist Microphone + Wyoming Protocol.
Could you kindly see: https://community.home-assistant.io/t/wyoming-protocol-after-updating-to-ha-2025-5-4-upwards/1013157
Assistant Microphone is deprecated , use Assist Satellite
Thank you - I have taken your advice.
I will post updates here for the benefit of other users too.
Thanks everything working fine so far.
