### Describe the issue you are experiencing
After updating from 2.1.1 to 2.2.1 …I get notifications in the log that it cannot start because of NumPy
The same issue happens with 2.2.2
### What type of installation are you running?
Home Assistant OS
### Which operating system are you running on?
Home Assistant Operating System
### Which app are you reporting an issue with?
Piper
### What is the version of the app?
2.2.1
### Steps to reproduce the issue
1. Update from 2.1.1 to 2.2.1
2. Broken.
### System Health information
## System Information
version | core-2026.2.0
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
container_arch | amd64
user | root
virtualenv | false
python_version | 3.13.11
os_name | Linux
os_version | 6.12.63-haos
arch | x86_64
timezone | Europe/Amsterdam
config_dir | /config
<details><summary>Home Assistant Cloud</summary>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 17.0
update_channel | stable
supervisor_version | supervisor-2026.01.1
agent_version | 1.8.1
docker_version | 29.1.3
disk_total | 30.8 GB
disk_used | 23.5 GB
nameservers | 2001:b88:1002::10, 192.168.178.2, 2001:730:3e42:1000::53, 2001:b88:1202::10
healthy | true
supported | true
host_connectivity | true
supervisor_connectivity | true
ntp_synchronized | true
virtualization | kvm
board | ova
supervisor_api | ok
version_api | ok
installed_addons | Z-Wave JS UI (7.0.0), Mosquitto broker (6.5.2), Piper (2.1.1), OpenThread Border Router (2.16.1), openWakeWord (2.1.0), SONOFF Dongle Flasher (1.3.0), Music Assistant (2.7.6), Terminal & SSH (9.22.0), Samba share (12.5.4), Zigbee2MQTT (2.8.0-1), Studio Code Server (6.0.1), ESPHome Device Builder (2026.1.4), Speech-to-Phrase (1.4.1), Whisper (3.0.1)
</details>
<details><summary>Dashboards</summary>
dashboards | 9
resources | 0
views | 69
mode | storage
</details>
<details><summary>Network Configuration</summary>
adapters | lo (disabled), enp6s18 (enabled, default, auto), docker0 (disabled), hassio (disabled), veth1ce741e (disabled), veth9805303 (disabled), veth598e9e3 (disabled), veth722769e (disabled), vethbe43386 (disabled), veth759ddf3 (disabled), vethefba249 (disabled), veth3f47fc6 (disabled), veth76920eb (disabled), veth91c4b03 (disabled), vethb414d81 (disabled), veth691f2d9 (disabled), veth9a2336f (disabled), vethef4c3f3 (disabled), wpan0 (disabled), veth02185ad (disabled)
ipv4_addresses | lo (127.0.0.1/8), enp6s18 (192.168.178.3/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), veth1ce741e (), veth9805303 (), veth598e9e3 (), veth722769e (), vethbe43386 (), veth759ddf3 (), vethefba249 (), veth3f47fc6 (), veth76920eb (), veth91c4b03 (), vethb414d81 (), veth691f2d9 (), veth9a2336f (), vethef4c3f3 (), wpan0 (), veth02185ad ()
ipv6_addresses | lo (::1/128), enp6s18 (fdaf:4780:6b5f:9b64:c83d:5007:362b:6ba4/64, fe80::8c23:5735:aa39:5b92/64), docker0 (fe80::84e:48ff:fef8:e53c/64), hassio (fd0c:ac1e:2100::1/48, fe80::d407:95ff:fe40:8028/64), veth1ce741e (fe80::4dc:68ff:fe93:274b/64), veth9805303 (fe80::9493:acff:fe5f:41e2/64), veth598e9e3 (fe80::4ee:6ff:fe42:e61d/64), veth722769e (fe80::9042:7bff:fe62:d7fb/64), vethbe43386 (fe80::f44a:7bff:fe20:fb11/64), veth759ddf3 (fe80::1813:c0ff:fee5:584b/64), vethefba249 (fe80::1060:27ff:fec5:4663/64), veth3f47fc6 (fe80::78b0:7bff:fe3c:fc70/64), veth76920eb (fe80::c14:e9ff:fe0e:badb/64), veth91c4b03 (fe80::6c7f:c2ff:feaa:532b/64), vethb414d81 (fe80::48b9:78ff:fe21:19a0/64), veth691f2d9 (fe80::98a1:d8ff:fe05:f487/64), veth9a2336f (fe80::a476:b3ff:fea9:9976/64), vethef4c3f3 (fe80::a478:25ff:fe5c:bef6/64), wpan0 (fde8:7c8c:195f:e045:0:ff:fe00:fc11/64, fde6:d33a:b805:1:11db:7fe8:8366:c579/64, fde8:7c8c:195f:e045:0:ff:fe00:fc10/64, fde8:7c8c:195f:e045:0:ff:fe00:fc38/64, fde8:7c8c:195f:e045:0:ff:fe00:fc00/64, fde8:7c8c:195f:e045:0:ff:fe00:9800/64, fde8:7c8c:195f:e045:784:d969:dc13:e9fe/64, fe80::608b:dbf6:8a67:404a/64), veth02185ad (fe80::bc45:75ff:fe5c:b64f/64)
announce_addresses | 192.168.178.3, fdaf:4780:6b5f:9b64:c83d:5007:362b:6ba4, fe80::8c23:5735:aa39:5b92
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | April 5, 2025 at 2:38 AM
current_recorder_run | February 5, 2026 at 1:41 PM
estimated_db_size | 14532.58 MiB
database_engine | mysql
database_version | 12.2.1
</details>
<details><summary>Spotify</summary>
api_endpoint_reachable | ok
</details>
### Anything in the Supervisor logs that might be useful for us?
```txt
### Anything in the app logs that might be useful for us?
```txt
### Additional information
_No response_
