edtwodth
(Finn Edtwodth)
1
Hi, newbie here …
I have tried searching the forum but have not yet found a solution.
I just purchased a Wyze Cam V2 and have the following in my configuration file, but it doesn’t show up under entities?
ffmpeg:
Camera:
- platform: ffmpeg
input: "rtsp://xxxx:[email protected]/live"
Hassbian, Raspberry pi 3 B+
Have you flashed the rtsp firmware from Wyze onto the camera? There are instructions to do so on Wyze’s site, along with the firmware files.
edtwodth
(Finn Edtwodth)
3
Yes, i can see the stream in vlc
edtwodth
(Finn Edtwodth)
4
I can now see the entity i HA, but in lovelace nothing shows?!
24|473x102
What are you running HASS on/what flavor of HASS (hassbian/docker/hass.io, etc).
If you’re running on a Pi you may need to install ffmpeg from what I can remember.
edtwodth
(Finn Edtwodth)
6
Hi, as i wrote i’m running Hassbian, Raspberry pi 3 B+
I have ffmpeg installed
It will not work as a direct intergration in HA as rtsp, you have to use Motion-Eyes (etc.) to be able to stream the WyzeCam…
Check out this video to walk you through.
edtwodth
(Finn Edtwodth)
9
Ok thanks … i will try that
That was happening. I kept regenerating the URL and eventually it stopped failing. There’s an update I need to install I hear.
edtwodth
(Finn Edtwodth)
11
I got it to work with motioneye - thanks all
