Wyze devices no longer working with HA after July update
None of my wyze devices work (and I have a house full of them) with HA Zigbee. Until updates in July they worked well and were good products… LED Strips, bulbs, cameras, sensors of all types just worked and automated well. I understand from GitHub comments it may be a “Certificate” issue. Sounds like a software upgrade somewhere could correct a certificate! Hope this gets resolved or I will have to abandon. Help?
downgrade HA if it works on a previous version.
Yes, that works to downgrade but, then, I can’t upgrade other items that require later HA updates. While Wyze things work again, this is unfortunately less than a good resolving of the issue. Need to be able to move on with HA… Thanks for the reply. Bill
Unfortunately, you have to wait for bug fixes so these are the options that you have.
A search would have found previous reports of this (Wyze integration fails and Wyze Integration not working after update).
Those both link to the Github Issue (#870) tracking the problem. The issue thread includes a workaround without needed to downgrade HA (by adding am additional CA until Wyze reissues the cert). See the comment at this link for instructions on the workaround:
