Wyze Floodlight Cam integration issue
When using HA with the HACS Wyze integration to turn the light on/off on a Wyze Cam Floodlight V2, the toggle moves, but then moves back to the original state and the light does not come on/turn off. When turning the light on/off from the Wyze app, the state does not change in HA. Siren and Power toggles work. Testing functionality again today with a z-wave switch as a trigger. Automation is set to turn on/off floodlight when switch is turned on/off. This does not work. However when the automation is set to turn on/off the power to the floodlight (and camera) when switch is on/off, this works. Really hoping to replace some old, dumb floodlights with the Wyze Cam floodlight/camera. Any thoughts? Thank you!
Still looking for a solution here. Anyone have any thoughts?
