I’ve just installed Hass.io for the first time. I’ve managed to add the Envisalink 4 component and my PIRs seem to be reporting movement in the logs correctly. I’d now like to add my X10 CM11A device, but when I tried adding the x10 platform entry to configuration.yaml and restarted, the logs reported errors about Heyu being missing.
Given what I’ve read and seen so far I get the impression that an Addon containing the Heyu binary will be needed before I can expect the x10 component to work correctly in the new Hass.io environment. Is that right?
