X10 WS467 Wall Switch
I am new to HCA and have just a simple setup to control lights in the house.
I have all working except the front door which has X10 WS467 wall switch.
It will not activate from HCA manually and will not work scheduled. Any help to
get the switch working will be appreciated.
How do you have it set up in HA? And how are you using it in an automation?
Post the code. Make sure you follow the instructions in the blue box at the top of the page to format it properly.
Set up is simple Address House Code A Unit Code 9
Device is X10 Switch, WS467 Wall Switch.
Schedule to come on at 5PM
Schedule to turn off at 10PM
All other devices are for lights in house and can be activated
manually from in HCA and all work to schedules.
This one will neither activate from in HCA or on schedules
What did you do to get the switch into Home Assistant? Did you manually program it in or did HA discover the switch?
I programed it as a X10, switch, WE467
I meant WS467
