X86 install: connection refused on 8123 but can see observer on 4357
I’m updating my hardware so that I can run the new 64 bit core releases. I installed haos_generic-aarch64-17.0.img on a minipc
everything installed just fine by installing from a live USB of fedora.
HA boots fine and I see the ha prompt but I cannot access the ui on port 8123 (refused) to begin the onboarding process. As stated in the title I am able to see the Observer page and it shows everything as normal (supervisor connected, support supported, and health healthy)
I tried to ssh in but ssh is also refused.
Check ha supervisor logs and ha core logs. Which Mini PC do you have?
That is for an ARM processor.
Do you have an ARM processor in your mini PC?
Maybe I copied the wrong name because I can’t imagine the ARM image would even not in an X86 machine. I’ll check when I have physical access to the box
I reinstalled and it is now fixed. Thanks for the help. I think the problem was that I shutdown from TTY after installing but before onboarding assuming I could onboard after moving it.
thanks. I am fairly sure it was the right image. I think the problem happened because I shutdown and relocated the box before onboarding. reinstalling and recovering the backup before relocation worked.
What mini-PC uses an ARM processor?
