📜 Click to expand log
2025-04-14 17:00:58.778 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration webrtc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-04-14 17:00:58.781 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration anniversaries which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-04-14 17:00:58.783 ERROR (SyncWorker_0) [homeassistant.loader] Error parsing manifest.json file at /config/custom_components/samsungtv_custom_old/manifest.json: unexpected character: line 10 column 3 (char 262)
2025-04-14 17:00:58.784 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration auto_backup which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-04-14 17:00:58.786 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration wyzeapi which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-04-14 17:00:58.788 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration samsungtv_tizen which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-04-14 17:00:58.791 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-04-14 17:00:58.793 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration anniversary which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-04-14 17:00:58.795 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration emporia_vue which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-04-14 17:00:58.796 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-04-14 17:00:58.798 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-04-14 17:00:58.801 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration whatsigram_messenger which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-04-14 17:00:58.804 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration sengledapi which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-04-14 17:00:58.805 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration openhasp which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-04-14 17:01:06.660 ERROR (MainThread) [homeassistant.components.sensor] Platform energy does not generate unique IDs. ID 05d33f5ef559bd56cf8a781c59847a51_grid_cost is already used by sensor.power_shop_123_1d_cost - ignoring sensor.power_shop_123_1d_cost
2025-04-14 17:01:08.578 WARNING (ImportExecutor_0) [homeassistant.components.media_player] DEVICE_CLASS_TV was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaPlayerDeviceClass.TV instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.583 WARNING (ImportExecutor_0) [homeassistant.components.media_player] DEVICE_CLASS_TV was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaPlayerDeviceClass.TV instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.588 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] MEDIA_TYPE_CHANNEL was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaType.CHANNEL instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.592 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] SUPPORT_NEXT_TRACK was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaPlayerEntityFeature.NEXT_TRACK instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.597 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] SUPPORT_PAUSE was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaPlayerEntityFeature.PAUSE instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.602 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] SUPPORT_PLAY was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaPlayerEntityFeature.PLAY instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.607 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] SUPPORT_PLAY_MEDIA was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaPlayerEntityFeature.PLAY_MEDIA instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.611 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] SUPPORT_PREVIOUS_TRACK was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaPlayerEntityFeature.PREVIOUS_TRACK instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.616 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] SUPPORT_SELECT_SOURCE was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaPlayerEntityFeature.SELECT_SOURCE instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.622 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] SUPPORT_TURN_OFF was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaPlayerEntityFeature.TURN_OFF instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.627 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] SUPPORT_TURN_ON was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaPlayerEntityFeature.TURN_ON instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.633 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] SUPPORT_VOLUME_MUTE was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaPlayerEntityFeature.VOLUME_MUTE instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.640 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] SUPPORT_VOLUME_STEP was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaPlayerEntityFeature.VOLUME_STEP instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.644 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] SUPPORT_VOLUME_SET was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaPlayerEntityFeature.VOLUME_SET instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.652 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] MEDIA_TYPE_APP was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaType.APP instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.656 WARNING (ImportExecutor_0) [homeassistant.components.media_player.const] MEDIA_TYPE_URL was used from samsungtv_tizen, this is a deprecated constant which will be removed in HA Core 2025.10. Use MediaType.URL instead, please report it to the author of the 'samsungtv_tizen' custom integration
2025-04-14 17:01:08.688 WARNING (MainThread) [py.warnings] /config/custom_components/samsungtv_tizen/media_player.py:703: RuntimeWarning: coroutine 'SamsungTVDevice._gen_installed_app_list' was never awaited
self._gen_installed_app_list()
2025-04-14 17:01:11.948 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'webrtc' accessed lovelace_data['resources'] instead of lovelace_data.resources at custom_components/webrtc/utils.py, line 129: resources: ResourceStorageCollection = hass.data["lovelace"]["resources"]. This will stop working in Home Assistant 2026.2, please create a bug report at https://github.com/AlexxIT/WebRTC/issues
2025-04-14 17:01:12.664 ERROR (MainThread) [homeassistant.components.zwave_js] Failed to set the Z-Wave JS add-on options: not a valid value for dictionary value @ data['options']. Got {'device': '/dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_61201F3A-if00-port0', 's0_legacy_key': 'E0A2D013D3D95C0DFC2B42C5E50650A4', 's2_access_control_key': 'A579D5283916F3715B87D684BA91FAE8', 's2_authenticated_key': 'EB8515D4264B1E05A41B0161CB4C926A', 's2_unauthenticated_key': 'B7B4B0600A51CFD41D926C3F6D8C2BA0', 'lr_s2_access_control_key': '620ECE416CA651BB4DE9D0386373826A', 'lr_s2_authenticated_key': '9421F1B7AEAC2EE77377EDC8C43D771A'}
2025-04-14 17:01:18.908 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to load_default_certs with args (<ssl.SSLContext object at 0x7fe48a9d05f0>, <Purpose.SERVER_AUTH: _ASN1Object(nid=129, shortname='serverAuth', longname='TLS Web Server Authentication', oid='1.3.6.1.5.5.7.3.1')>) inside the event loop by custom integration 'sengledapi' at custom_components/sengledapi/sengledapi/sengledapi.py, line 288: SESSION.mqtt_client.tls_set_context() (offender: /usr/local/lib/python3.13/ssl.py, line 722: context.load_default_certs(purpose)), please report it to the author of the 'sengledapi' custom integration
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#load_default_certs
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 227, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 213, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 154, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 712, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 683, in run_forever
self._run_once()
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 2040, in _run_once
handle._run()
File "/usr/local/lib/python3.13/asyncio/events.py", line 89, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/setup.py", line 171, in async_setup_component
result = await _async_setup_component(hass, domain, config)
File "/usr/src/homeassistant/homeassistant/setup.py", line 422, in _async_setup_component
result = await task
File "/config/custom_components/sengledapi/__init__.py", line 54, in async_setup
await sengledapi_account.async_init()
File "/config/custom_components/sengledapi/sengledapi/sengledapi.py", line 53, in async_init
self._access_token = await self.async_login(
File "/config/custom_components/sengledapi/sengledapi/sengledapi.py", line 91, in async_login
self.initialize_mqtt()
File "/config/custom_components/sengledapi/sengledapi/sengledapi.py", line 288, in initialize_mqtt
2025-04-14 17:01:18.918 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to set_default_verify_paths with args (<ssl.SSLContext object at 0x7fe48a9d05f0>,) inside the event loop by custom integration 'sengledapi' at custom_components/sengledapi/sengledapi/sengledapi.py, line 288: SESSION.mqtt_client.tls_set_context() (offender: /usr/local/lib/python3.13/ssl.py, line 534: self.set_default_verify_paths()), please report it to the author of the 'sengledapi' custom integration
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#set_default_verify_paths
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
result = await task
2025-04-14 17:01:22.979 WARNING (MainThread) [homeassistant.config_entries] Config entry '[email protected]' for tuya integration could not authenticate: Authentication failed. Please re-authenticate
2025-04-14 17:01:24.042 WARNING (MainThread) [homeassistant.helpers.frame] Detected code that calls `async_add_job`, which should be reviewed against https://developers.home-assistant.io/blog/2024/03/13/deprecate_add_run_job for replacement options. This will stop working in Home Assistant 2025.4, please report this issue
Stack (most recent call last):
sys.exit(main())
self.run_forever()
self._run_once()
handle._run()
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 68, in run_callback
future.set_result(callback(*args))
File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 243, in _report_usage
_report_usage_no_integration(what, core_behavior, breaks_in_ha_version, err)
File "/usr/src/homeassistant/homeassistant/helpers/frame.py", line 380, in _report_usage_no_integration
_LOGGER.warning(msg, stack_info=True)
2025-04-14 17:01:24.045 WARNING (MainThread) [py.warnings] /config/custom_components/samsungtv_tizen/media_player.py:703: RuntimeWarning: coroutine 'SamsungTVDevice._gen_installed_app_list' was never awaited
2025-04-14 17:01:27.811 WARNING (ImportExecutor_0) [homeassistant.components.light] ATTR_COLOR_TEMP was used from sengledapi, this is a deprecated constant which will be removed in HA Core 2026.1. Use kelvin equivalent (ATTR_COLOR_TEMP_KELVIN) instead, please report it to the author of the 'sengledapi' custom integration
2025-04-14 17:01:27.824 WARNING (ImportExecutor_0) [homeassistant.components.light] ATTR_COLOR_TEMP was used from sengledapi, this is a deprecated constant which will be removed in HA Core 2026.1. Use kelvin equivalent (ATTR_COLOR_TEMP_KELVIN) instead, please report it to the author of the 'sengledapi' custom integration
2025-04-14 17:01:27.833 WARNING (MainThread) [homeassistant.components.light] None (<class 'custom_components.sengledapi.light.SengledBulb'>) sets invalid supported color modes {<ColorMode.COLOR_TEMP: 'color_temp'>, <ColorMode.BRIGHTNESS: 'brightness'>, <ColorMode.HS: 'hs'>}, this will stop working in Home Assistant Core 2025.3, please report it to the author of the 'sengledapi' custom integration
2025-04-14 17:01:27.834 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'sengledapi' is using mireds for warmest light color temperature, when it should be adjusted to use the kelvin attribute `_attr_min_color_temp_kelvin` or override the kelvin property `min_color_temp_kelvin`, possibly with default DEFAULT_MIN_KELVIN (see https://github.com/home-assistant/core/pull/79591). This will stop working in Home Assistant 2026.1, please report it to the author of the 'sengledapi' custom integration
2025-04-14 17:01:27.834 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'sengledapi' is using mireds for coldest light color temperature, when it should be adjusted to use the kelvin attribute `_attr_max_color_temp_kelvin` or override the kelvin property `max_color_temp_kelvin`, possibly with default DEFAULT_MAX_KELVIN (see https://github.com/home-assistant/core/pull/79591). This will stop working in Home Assistant 2026.1, please report it to the author of the 'sengledapi' custom integration
2025-04-14 17:01:27.835 WARNING (MainThread) [homeassistant.components.light] None (<class 'custom_components.sengledapi.light.SengledBulb'>) sets invalid supported color modes {<ColorMode.COLOR_TEMP: 'color_temp'>, <ColorMode.BRIGHTNESS: 'brightness'>, <ColorMode.HS: 'hs'>}, this will stop working in Home Assistant Core 2025.3, please report it to the author of the 'sengledapi' custom integration
2025-04-14 17:01:28.559 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.water_heater_day (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) is using state class 'total_increasing' which is impossible considering device class ('current') it is using; expected None or one of 'measurement'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2025-04-14 17:01:28.559 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.water_heater_day (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) is using native unit of measurement 'watts' which is not a valid unit for the device class ('current') it is using; expected one of ['mA', 'A']; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2025-04-14 17:01:28.562 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.water_heater_month (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) is using state class 'total_increasing' which is impossible considering device class ('current') it is using; expected None or one of 'measurement'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2025-04-14 17:01:28.562 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.water_heater_month (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) is using native unit of measurement 'watts' which is not a valid unit for the device class ('current') it is using; expected one of ['mA', 'A']; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2025-04-14 17:01:28.566 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.water_heater_year (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) is using state class 'total_increasing' which is impossible considering device class ('current') it is using; expected None or one of 'measurement'; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2025-04-14 17:01:28.566 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.water_heater_year (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) is using native unit of measurement 'watts' which is not a valid unit for the device class ('current') it is using; expected one of ['mA', 'A']; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2025-04-14 17:01:29.115 WARNING (MainThread) [homeassistant.components.light] None (<class 'custom_components.sengledapi.light.SengledBulb'>) sets invalid supported color modes {<ColorMode.COLOR_TEMP: 'color_temp'>, <ColorMode.BRIGHTNESS: 'brightness'>, <ColorMode.HS: 'hs'>}, this will stop working in Home Assistant Core 2025.3, please report it to the author of the 'sengledapi' custom integration
2025-04-14 17:01:29.236 WARNING (MainThread) [homeassistant.components.light] None (<class 'custom_components.sengledapi.light.SengledBulb'>) sets invalid supported color modes {<ColorMode.COLOR_TEMP: 'color_temp'>, <ColorMode.BRIGHTNESS: 'brightness'>, <ColorMode.HS: 'hs'>}, this will stop working in Home Assistant Core 2025.3, please report it to the author of the 'sengledapi' custom integration
2025-04-14 17:01:29.256 WARNING (MainThread) [homeassistant.components.light] None (<class 'custom_components.sengledapi.light.SengledBulb'>) sets invalid supported color modes {<ColorMode.COLOR_TEMP: 'color_temp'>, <ColorMode.BRIGHTNESS: 'brightness'>, <ColorMode.HS: 'hs'>}, this will stop working in Home Assistant Core 2025.3, please report it to the author of the 'sengledapi' custom integration
2025-04-14 17:01:29.620 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for esphome-web-c0223c @ 192.168.1.219: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.1.219', port=6053))]: [Errno 111] Connect call failed ('192.168.1.219', 6053) (SocketAPIError)
2025-04-14 17:01:29.683 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform esphome does not generate unique IDs. ID 4C:75:25:D6:73:A8-binary_sensor-brl already exists - ignoring binary_sensor.brl_2
2025-04-14 17:01:29.683 ERROR (MainThread) [homeassistant.components.binary_sensor] Platform esphome does not generate unique IDs. ID 4C:75:25:D6:73:A8-binary_sensor-rc522_rfid_tag already exists - ignoring binary_sensor.rc522_rfid_tag
2025-04-14 17:01:29.748 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for esphome-web-fa9c88 @ 192.168.1.196: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.1.196', port=6053))]: [Errno 111] Connect call failed ('192.168.1.196', 6053) (SocketAPIError)
2025-04-14 17:01:29.750 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for esphome-web-0bdc36 @ 192.168.1.187: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.1.187', port=6053))]: [Errno 111] Connect call failed ('192.168.1.187', 6053) (SocketAPIError)
2025-04-14 17:01:29.751 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for esphome-web-ce50c4 @ 192.168.1.171: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.1.171', port=6053))]: [Errno 111] Connect call failed ('192.168.1.171', 6053) (SocketAPIError)
2025-04-14 17:01:29.756 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for esphome-web-ecaf14 @ 192.168.1.171: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.1.171', port=6053))]: [Errno 111] Connect call failed ('192.168.1.171', 6053) (SocketAPIError)
2025-04-14 17:01:29.763 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for esphome-web-a37f48 @ 192.168.1.219: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.1.219', port=6053))]: [Errno 111] Connect call failed ('192.168.1.219', 6053) (SocketAPIError)
2025-04-14 17:01:29.780 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for 192.168.1.66: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.1.66', port=6053))]: [Errno 113] Connect call failed ('192.168.1.66', 6053) (SocketAPIError)
2025-04-14 17:01:29.808 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for esphome-web-f846c8 @ 192.168.1.196: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.1.196', port=6053))]: [Errno 111] Connect call failed ('192.168.1.196', 6053) (SocketAPIError)
