Xiaomi Air Purifier MAX Pro (zhimi.airpurifier.sa2) - Unimplemented mode?
Good day!
So far I have successfully set up the purifier in Home Assistant with the following config in configuration.yaml
fan:
    - platform: xiaomi_miio
      host: <>
      token: <>
      model: zhimi.airpurifier.sa2
      name: Xiaomi Air Purifier MAX Pro
Had to do some tinkering to get the proper toggles and favorite levels and I have been successful.
This purifier has “Levels” and can be changed in the Mi Home App. There are a total of three levels.
I have been successful in activating Levels 2 and 3 with the following code:
input_select:
  # Xiaomi Air Purifier MAX Pro
  xiaomi_airpurifier_mode:
    options:
      - Auto
      - Silent
      - Favorite
      - Medium
      - Strong
    icon: "mdi:animation-outline"
Medium is Level 2 and Strong is Level 3. I did some troubleshooting and found out that if you leave the purifier on Level 1 (via Mi Home App), Home Assistant fails to recognize it. Looking at the logs, I get this:
I hope that this can be fixed. Thanks!
