Xiaomi Aqara motion sensors
I have been facing some issues with the Xiaomi motion sensor connected using a HUSBZB-1 stick. All my sensors seem to be working fine except for the xiaomi motion sensor, are any of you using it? What should i be looking for? I checked the battery voltage and it is at 3.00 volts. The sensor is able to detect the lux value but not the motion. I was planning on using this to turn on lights, but since the sensor will not detect motion I am unable to use it. Any suggestions?
I had problems with this sensor too.I am using zigbee2mqtt my problem was tha these sensor dont work when they are mounted upsidedown.
When i mount the sensor the planned way (led up) everything worked fine for me.
i have it sitting the correct way, battery compartment at the bottom. It can sense the change in light but not motion.
