Xiaomi bad accuracy
Have a Xiaomi mobile with miui 14. Run the app against cloud flare. Have tried a lot of different settings gave full access no battery limitations etc. have also tried recommendations in the documentation when troubleshooting but get it to work for a while when I check the log then it can go to accuracy of 3000m. what can be done to fix this
After you confirm that those are valid reports you need to update the sensors setting
Setting > Companion app > manage sensors > background location > change accuracy to 3000
won’t there be problems with type zones proxymeter if you set it up to 3000?
Has nothing to do with that
