I have a Xiaomi Aqara single button, I integrate Zigbee with the Zigate device by this component : https://github.com/doudz/homeassistant-zigate
I cannot use ZHA because I use Zigate by Wifi.
I have an automation which is triggered when my button changes state, so when I push on it :
- alias: 'bouton spots cuisine'
platform: state
entity_id: zigate.00158d000214f0ad
service: switch.toggle
entity_id: switch.qubino_goap_zmnhadx_flush_1_relay_switch
This works fine, but the button changes state alone every 50 minutes, and then triggered the automation :
Below my device actual config :
“lqi_percent”: 59,
“type”: “lumi.sensor_86sw1”,
“manufacturer”: null,
“receiver_on_when_idle”: false,
“missing”: false,
“generic_type”: “”,
“discovery”: “auto-discovered”,
“groups”: {},
“datecode”: null,
“battery_voltage”: 3.035,
“battery_level”: 79,
“addr”: “e00c”,
“id”: 0,
“ieee”: “00158d000214f0ad”,
“last_seen”: “2019-10-14 10:05:11”,
“lqi”: 150,
“mac_capability”: “10000000”,
“power_type”: 0,
“friendly_name”: “Bouton spots cuisine”,
“icon”: “mdi:access-point”
I have no other automation which could be interact with it.
Should I change a parameter to avoid that ?
Or my automation is not good?
Thanks !
